My ETKA has died
Finally locked itself out so uninstalled.
What are you ETKA users out there doing to keep up to date and not getting locked out? Feel free to PM me if anything should be kept out the public eye. ;)
if you had rolled the date back on your PC it would have worked
I like my PC having the right date :D
Trying to see if I can get V7.3 (2011) and then stop it from ever updating. Struggling though.
I have a program that allows you to trick a running program into thinking it's a different date. I'll drop you a pm about it later when I'm back home.
I've just sent you a PM mate.
Weekend turned out to be a bit longer than I was expecting :D
Cheers, will check at home.
As I uninstalled it, will need to D/L a fresh copy from somewhere. Assume you used the attached OK with etka 7.2?
Let me know if this is Resolved Jason. If not - I can help :thumbup:
I've not used it for etka, I only used it for Autodata. I've had etka 7.2 installed for about 6 months or so and it's still working so I assume the "version" that I have works in a different way.
ETKA 7.3 is the latest version, saying that my 7.0 is still working although there have need been any updates since the end of May that I have been able to find.
