engine mount sacers
Does anyone know of anywhere that sells these? wud rather this than a shallow or dry sumb.
What exactly is a 'sacer' ? Never heard of it.
Mis type should be spacer.
Ah right, so to raise the engine, but by how much. Things to consider. Drive shaft angle, exhaust hangers at front will need to be shorter. Gear cable linkage will need adjusting.
Never seen any for the fabia or other vw group cars....usually people fit a small/short sump because of the other problems that are mentioned above. B)
A Lot of the mk4 golf boys fit hocky pucks to raise the engine.
Dont know how this would do with the Fabia though.
If seen this done on a golf, he fitted 15mm spacers to lift the sump up a little bit
