Devilsown Water Methanol Kits Group Buy
Hi People, we are looking at organising a group buy on Devilsown water methanol kits.
There are realistics 2 options people will go for:
  1. Base Kit - 6-30psi
  2. Progressive kit 30psi
Both kits work very well on VAG cars, I have personally run the base kit on my hybrid Fabia gaining approx 20-30bhp all the way through the power curve.
Discounts will vary depending on number of kits ordered but initial prices are:
  • Base Kit (6-30psi) - £200
  • Progressive Kit (30psi) - £260
If we can get a good quantity of orders I think we could probaby drop another 10%. Discounts can also be had on extras such as the dual nozzle upgrade, which come highly recommended and the direct port kits, which I personally am gonna run in my own car! Other extras include the boot tank etc.
We can also offer a full fitting from our workshop in Thame, Oxfordshire
We will also supply high grade Methanol 99.95% pure by the litre @ £1/litre. This will dilute to between 2 and 4 litres of fluid depending on how you wish to run it. This is a simple, low cost BHP gain!
Thanks for the interest, PM me if you need any more info or prices.
Please Note - BRISKODA and it's Staff are exempt from any legal liability if problems arise from the buy. This buy is not an offical BRISKODA organised buy and therefore BRISKODA or it's Staff, CANNOT be held responsible for any wrong doing that may occur.
Please start a list if you are genuinely interested below :)
Edited by ninja_alex
HOW MUCH CAN AIR TEMP EFFECT PERFORMANCE YOU ASK???
From the table below, you will note that air at 0C contains almost 30% more oxygen per given volume, than air at 77C.
Air Temperature
Air Density
% increase of oxygen
77C
0.9950 kg/m^3
40C
1.113 kg/m^3
+ 12% oxygen
27C
1.1614 kg/m^3
+ 17% oxygen
0C
1.2763 kg/m^3
+ 28% oxygen
So if your car is tuned for say 12.0:1 fuel mixture (rich) for maximum power and the air going into your engine is at 77C, you might make say 241bhp @ wheels. Now if you could get that intake air down to 0C and still have your engine tuned at 12.0:1 fuel mixture, you will make 30% more power based simply on oxygen levels in the air = 241bhp @ wheels x 1.3 = 314bhp @ wheels. That’s a massive 73bhp increase!!! Now obviously, unless your using dry ice somewhere along your intake path, you won’t get the air to 0C, but that is just to give you an indication of the true effects of air temps and their relation to power output.
The kit allows you to run higher boost, advance ignition and lean out air fuel ratios.
The Devils Water Injection System is currently in use on the some of the fastest vehicles around, it has applications in drag, drift and circuit racing as well as on the street.
Alcohol does not cause any problems to your engine. It actually "steam" cleans the inside of your throttle body, intake, heads, valves, and exhaust!
  • ninja_alex - Base kit x2 with extras
Progressive kit 30psi + 1
im in northern ireland, what about fitting? and with the base kit what extras would be of benefit?
And looking at their site there is no kit listed for 1.9tdi?
Here are some photos of mine and another install showing where the nozzles and pump/tanks can be placed.
Alex
  • 4 weeks later...
Any more on this??
You can get these kits for this price or slightly cheaper on the Devils own website for this weekend only I believe.
