52k - third variable service.
The 1000 miles 'till service indicator appeared yesterday. I'm going to book it in for a service in the next couple of weeks. It's covered just under 52k at the moment.
I'm thinking of the following for the service.
* Oil and filter
* Pollen filter
* Oil pick up pipe
* Brake fluid
* New spark plugs - oem?
It's had the cambelt done last year (inc new water pump), a new air filter last week, a new fuel filter last year. The brakes were stripped, inspected and cleaned three months ago. It's never had new plugs, it did blow a couple of coil packs after the remap three years ago, but none since. Is there anything else you can think of that would need doing at 52k?
Thanks,
Andrew.
i would say coolant and the fuel filter should be changed every 2-3 years i cant think of anything else unless you think your aircon needs to be re-gassed due to the hot weather we are haing :p
oh and air filter haha
Air con is fine and was done 18 months ago. Thanks for the reply. :thumbup:
get gear oil done - oil is only £12 and makes a big difference
also get oem plugs - no point in anything else tbh
