Cruise Control: > May 2010 VCDS Scan
I order the cruise control and new slip ring to be fitted with my Yeti Elegance, (140 CR CLCB) can some body please post the complete VCDS scan of there yeti with factory fitted cruise control, this will help me identify the coding as well as few of the faults that I am currently getting after the installation, the major one looks like the cruise control wire from T16o/5 (SWCM) is not connected to the ECU ;-(, currently the new SWCM need to be coded so that my horn, and steering control need to start working!
Thanks in advance for you help in this regard.
-Pramod
-Pramod
Here you are.
Friday,05,August,2011,
VCDS Version: Release 10.6.4
Data version: 20110418
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFHC) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 DB HW: 03L 906 018 BR
Component: R4 2,0L EDC H23 7098
Revision: 42H23--- Serial number:
Coding: 001D0012042700080000
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_ECM20TDI01103L906018DB 003004
ROD: EV_ECM20TDI01103L906018DB.rod
VCID: 6DD455F20D01
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 013 L HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2601
Revision: 05351113 Serial number: 00001105062202
Coding: 0000020
VCID: 1A3E4E2EAC0F
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 933F400E092801FCC91402ED9019808A350000
VCID: 76E67A9E7857
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 BE HW: 3T0 907 044 BE
Component: Climatronic H16 0402
Revision: 00006001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_Climatronic_SK35.rod
VCID: 76E67A9E7857
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 H HW: 1K0 937 086 H
Component: BCM PQ35 M 103 0615
Revision: 00103 AE
Coding: 4E000ABBE05BF1C040080080110001E4437000AE726D85605C8140000040
VCID: 3564BD9225D1
Part No: 5L2 955 119 A
Component: SK356 26 0604
Coding: 00F7B5
Part No: 1K0 955 559 AH
Component: RLS 100511 05 54 0403
Coding: 0730ED
Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Address 10: Park/Steer Assist (J446) Labels: 5J0-919-475.clb
Part No SW: 5J0 919 475 A HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0005
Revision: --H11--- Serial number: 32901112600153
Coding: 118113
Shop #: WSC 08360 210 01865
ASAM Dataset: EV_EPHVA14SKxxx0000 001001
ROD: EV_EPHVA14SKxxx0000.rod
VCID: 3360838A2BA5
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RA576UN
Coding: 00005442
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360_SK35.rod
VCID: 316C8982D1B9
Driver's Airbag Crash Sensor:
Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME3E253260ZZZS
Passenger Side Airbag Crash Sensor:
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME51313260ZZZF
Driver's Rear Airbag Crash Sensor:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME743D1E44ZZZ+
Passenger's Rear Airbag Crash Sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME4A211E46ZZZY
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110508100049
Coding: 188A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: N/A
VCID: 7EF662BE5067
Part No SW: 3T0 959 537 HW: 3T0 959 537
Component: E221__MFL-URO H07 0012
Coding: 820000
No ASAM data for: "EV_SMLSNGVOLWSXS" (SK35)
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5L0 920 940 H HW: 5L0 920 940 H
Component: KOMBI H21 0420
Serial number: 00000000000000
Coding: 720E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 316C8982D1B9
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 070511F2002650
Coding: 356303
VCID: 316C8982D1B9
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
Component: Haldex 4Motion 3017
Coding: 0000005
Shop #: WSC 00000 000 00000
VCID: 4482D0567E0B
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H21 0420
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
VCID: EADEDEEEBCEF
Address 42: Door Elect, Driver (J386) Labels: 7N0-959-793.clb
Part No SW: 7N0 959 793 D HW: 7N0 959 793
Component: TSG FA H04 0400
Revision: Serial number: 0000115951080
Coding: 011402208001231004
VCID: 4380D34A7B05
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 71 3201
Revision: 00H20000
VCID: 346280962EAB
Address 4F: Centr. Electr. II (J520) Labels: None
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H35 0614
Coding: 050B0500
VCID: EFE8CFFA870D
Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Component: J394EE20SKB13 H02 0220
Address 52: Door Elect, Pass. (J387) Labels: 7N0-959-792.clb
Part No SW: 7N0 959 792 D HW: 7N0 959 792
Component: TSG BF H04 0400
Revision: Serial number: 0000116094362
Coding: 011400208001231004
VCID: 428ED64E641F
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 156 G HW: 1Z0 035 156 G
Component: BOLERO 015 0029
Revision: -----29S Serial number: SKZ4Z3L1128066
Coding: 0D0004000001
VCID: 3666BA9E38D7
Address 62: Door, Rear Left (J388) Labels: 7N0-959-795.clb
Part No SW: 7N0 959 795 D HW: 7N0 959 795
Component: TSG HL H03 0400
Revision: Serial number: 0000116054551
Coding: 010000200001531004
VCID: 4584CD527531
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H07 0100
Revision: 3A001001 Serial number: 00000134496265
Coding: 0100000100000000
VCID: 306A8C86DAB3
Address 72: Door, Rear Right (J389) Labels: 7N0-959-795.clb
Component: TSG HR H03 0400
Revision: Serial number: 0000116054550
VCID: 4584CD527531
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669946751
Coding: 0200000000010110
ASAM Dataset: UHVNA A01009
ROD: UHVNA_SK35.rod
VCID: E2CEB6CE44DF
End ---------------------------------------------------------------------
Thanks for the reply, it looks like the Steering wheel coding that you have is
Coding: 188A140000
While I was trying
Part No SW: 5K0 953 569 H HW: 5K0 953 569 H
Revision: --X01--- Serial number: 20110209201796
Coding: 1082140000
Even though the control modules are different but I am assuming you have as mentioned in the literature that came with the cruise control, if you have A then that need to be replaced with SWCM B and if D then it need to be replaced with H, that I have done need to try out the coding that you have and see if it makes any difference in behavior.
-Pramod
Tried coding the value still not getting the crusis control feature, looks like there is no signal flow from SWCM to ECU, the cruise control measuring value doesn't change at all!
Anyone with who have done the reftrofitting of cruise control on Yeti?
-Pramod
Got the Cruise Control working, Yeti from May 2010 onward need to wire the cruise control from SWCM to ECM
SWCM T16o/5 ECU T94a/64
Hope this helps if anybody is going to try!
Edited by Pramods
