Interior light need replacing.
Good morning all.
I was fitting a new stereo last night and running the microphone lead in to the area near the centre interior light. In a ham fisted type of way, in trying to remove the light I broke the dark plastic bit off which contains the switches. I suspect the slider switch that controls, on-door-off is also broken.
Would anyone have part number for this, and an easy way to get it out. I'm sure it must just clip in but I'm bugged if I could work it out.
Thanks very much.
I replaced mine recently, will get the part number from the invoice soon as i'm home from work, should be about 5ish
Thanks Mike, that's magic.
Good morning all.
Thanks very much.
have a look on ebay - i'm pretty sure that the unit is the same as the octavia which is the same as the golf.....
Think this is the part number - 3B0947105C47H the invoice just says light but pretty sure this is it. Make sure you get the onyx coloured one for the vRS as this has the 2 map lights, skoda dealer should know for definate
Thanks very much Mike.
No bother mate :thumbup:
