s3 upper brace bolt size?
Hi,does anybody know what length bolt to use i know it's either 8or10mm dia,just want to order them before the bar arrives.
About 25mm will do the job just fine. 8mm dia will be a slightly loose fit in the strutbrace holes, 10mm is correct, but will mean you will have to be super accurate with your drilling or your holes won't line up. I went for M8x25mm and Nyloc nuts.
PS the steel on the top of the turrets is double thickness - around 4mm so expect to spend a long time drilling, too, and probably wear out at least one drill bit.
HTH
Don't try & blast straight through the turret with an 8 or 10mm bit either,
Get a couple of 6 or 6.5mm bits and drill pilot holes first.Trust me it will make life a lot easier :)
I used 10 mm bolts...it's not going anywhere :)
Hmmm my experience of pilot holes in the past has been chipped drill edges and occasionally, snatching. However you pays yer money .....
Thanks alot guys for the swift replies,i will buy some 10mm bolts/nuts tommorrow as the bar should be in then also:)
