Brake backing plate?!
Does anyone know how much the front brake backing plates cost for the front of an RS from the stealer?
Just trying to get some ideas for whan i put this 312mm rear brake conversion kit together!
Might see if i can use front ones or have them custom made as part of the kit so it fits the 312 disc on the rear
Backing plates?
Do you mean the carriers which bolt the caliper to the hub?
no the shields, if you like that go on the inside of the disc
Ahh right I see. Thought you meant some kind of voodoo anti-squeal shims on the pads. :D
No idea TBH - Can't see them bring that expensive for a bit of tin TBH.
you mean those big plates that stop the dirt form getting onto the disk?
yeap!
