Passenger Door Window Glass Replacement
Tomorrow evening i tackle the task of replacing the glass in the passenger door window, does anyone know if this is an easy job ie are there particular items to watch out for etc., i have the replacement window , any help would be greatly appreciated
http://www.parkers.co.uk/advice/forum/topic.asp?TOPIC_ID=33082
Found a link for you, changing door glasses ain't too bad a job.. just take your time on it and you'll do fine.
Thank you Rusko, will let you know how i get on, may just call the dealer and ask for any heads up, Skoda has a habit of being different for the sake of being different, thanks again i appreciate it, Chick
http://www.parkers.c...?TOPIC_ID=33082
If your Fabia is a 2001 (going from your details) the carrier is bolted rather than riveted. It is quite straightforward and as long as you are methodical you should be fine!
All went well no rivets needed drilling, just grab a few plastics keepers before you start as it is inevitable some will break, the only thing to watch for when removing the inside metal panel is the connection from the doorlock knob to the lock/central locking mechanism, a very flimsy piece of plastic at the mechanism end is what holds a decent size gauge metal rod, the other end of which becomes your doorlock knob, top left hand corner, the glass goes in best from the outside, just take your time as was suggested to me and it was sound advice, thank you all :)
