The cost of towbar fitting
Hi John,
You have PM :)
Regards
Rich
Edited by richm
  • Replies 79
  • Views 15.7k
  • Iain, As Techie says there are 2 towing looms, one for basically the lighting system, and an additional one for the split charge and fridge. It says that in the brochure, so who ever advised you was
Towbar on. Nice job. Far enough out that it makes opening the tailgate easier with the bike rack on (just needs sliding back about half way - atera rack is really neat, 6 years old and still going strong), slight panic as it was a 13 pin not 7 as per my trailer but then I remembered the trailer was a 13 originally with a converter I prised off - everything works, select reverse I get a trailer picture on the screen and no parking sensor noise :)
What I don't get is any 'noise' when indicating but frankly I don't care. Just happy to be able to put the bike on the trailer now and not risk mashing the inside. I'll be towing my little 6ish foot trailer this weekend as well to go to the tip. Happy Days :)
Edited by alex_leigh67
Alex you'll find if a trailer indicator bulb fails you will get a bulb fail light and a double flash rate, the same as if a bulb had failed on the car. This replaces the conventional buzzer you would get with a universal wiring kit
Thanks for the info.
