Are seat base foam LH or RH specific?
Hi there, can anyone tell me if seat base foams on vRS's left or right hand specific, ie can you use a drivers foam on a passengers seat and vise versa?
Any info welcome, can the cover be swapped left to right?
The answer to this one is yes. The foams are not specific and can be swapped.
The answer to this one is also yes. The seat base cover is seperate to the seat back cover so can be swapped also.
I had the drivers side seat frame breaking through the foam on my vRS last year (quite common). I repaired the foam and then swapped the seat bases over.
HTH :thumbup:
Edited by Lee Rich
Thanks for the reply, just what i wanted to hear..
Keep on rollin :)
