Airbag fault
Hi again,
just recently replaced the swing radio system with Columbus. When removing the swing I had to unplug the airbag sensor cable which lies just under it. I placed the columbus, plugged again the airbag cable. Now when I turn on the engine it shows airbag fault and the corresponding led lights. I tested the airbag switch to see if it works and it did (I switched it off from the glove box and the led bellow the columbus light). Should I go to a Skoda service to erase the memory of the computer in case it finds this as an error?
You'll need to have Skoda reset it, or find someone with a VAG com that can clear it for you. HTH
That's what I thought. Ok thx a lot
