wheel bearing
Hi all can anyone tell me what size socket (male) i need to remove a hub nut, on my rear side its a female torque nut, need to change the bearing.
Thanks .
If its the same as the front its 30mm, make sure its not a hex socket as it wont fit the nut, which has more corners than a hexagon !
If no-one confirms this before tomorrow, I'll check.
Not sure I understand the wording of the question tbh.. But I'm almost certain it's a 30mm one from memory.
Yeh I got the bearing and it came with the 30 mm nut that's fine , its just the one on the car .needs a spline impact bit , just looking for the right size its a 1.6 petrol 2006 , thanks guys
