MFSW for FL Octy vRS - More Questions
A couple of weeks ago I mentioned I was looking to att a MFSW to my manual FL Octy vRS.
Having done some searching around I've found this item:
http://www.skodateile.cz/index.php?pg=product∏=356&menu=
Which appears to be the 3-spoke MFSW for Octy - which I assume will fit my car.
Quite nice price too - converts to £149.
It doesn't come with an airbag - is it safe to assume that my existing airbag would fit into this wheel?
I'm not going to even be attempting the fitting myself - I'll have a chat with Ben over at Shark.
Would I need anything else?
Is it just buy this steering wheel, remove the flappy paddles (something I really want to do) and then it would be a straight swap of airbag and then wheel and finally some coding?
Or would I require anything else?
Thanks chaps.
As you don't have an MFSW already, you'll also need a different version of the steering wheel controller.
Give Shark a ring anyway, as they might be able to sort a decent all-in price, including the wheel itself. And yes, as you already have an FL standard wheel, the airbag will swap over to this new one.
