wanted-splined shaft inside estelle gearbox
hi Im new to this but long story short Ive an estell with a 1.9 205gti engine in it. Its running and Im trying to sort out the niggles. One of them is the gearbox input shaft seal leaking.(I've got an adaptor plate made to fit the enine-it's running a small carb atm and a manta dizzy).
Anyway tonight I've taken off the clutch slave cylinder, pulled off the r clips inside the box then pulled off the input shaft and yip you've guessed it the shaft thing inside the gearbox has diappeared somewhere. Ive turned the box over by hand so I don't necessarily need to go fishing for it.
Does anyone have one? Know where I can get one?
Many thanks.
Iain.
Which splined shaft do you need ?.The one where the clutch plate works on ? ( input shaft ) ???.
Many thanks.
Iain.
