Gauges
I'm considering installing a couple of gauges (Wideband Air/Fuel Ratio and Water Temp) but don't know which is the best spot.
On the side beam I feel they will be a distraction and right above the cup holders below the center console box they will probably obstruct.
Got any ideas? Have you fitted a gauge? And where?
Thnks guys.
Just above the vents in the centre console slightly angled towards you?
That will probably raise an issue with visible cables :doh:
Looks good might need some modification to fit?
Defo some custom work will probably make this look almost factory installed.
To be honest I wouldnt have them on the steering cowl...
At least not for air/fuel and a temp gauge that need little monitoring. Id see it as more of an obstruction.
If they are on the steering area would this affect the air bags in any way ?
No, they would just be attached as part of the cowl,
connected on the plastic surround of the steering column.
ah okay.
Good luck with it.
