Brakes
Hi i was wondering what i would need for a big brake conversion and how to do it, Al's i can find are people selling or just brake disc most likely its me being a bit docile but i would appreciate it if any one could point me in the right direction.
Thanks Arron
Audi TT/Mk4 GTI Front calipers and cariers.
If you search ebay for "312mm VW" you will see loads of complete sets for £250
Discs and pads are a given
The cheapest and easiest big brake conversion is 312s. For this you need:-
1) A car with 288mm discs, and 16" or larger VAG wheels. Other makes of wheel may not clear the calipers.
2) A pair of 312mm caliper brackets, which can be had from a VAG dealership.
3) 312mm discs and a set of new pads.
If you mean the 312mm brake upgrade you`ll need Calipers, carriers & discs & pads. You can get them complete like this kit:
http://www.ebay.co.uk/itm/VW-AUDI-312mm-calipers-discs-and-pads-MK4-GOLF-TT-S3-/280735608130?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item415d256d42#ht_695wt_952
Or just get the calipers and carriers so you can get your own discs & pads
http://www.ebay.co.uk/itm/VW-AUDI-312mm-calipers-and-carriers-MK4-GOLF-TT-S3-/270814593483?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f0dcec1cb#ht_500wt_969
You need them for MK4 golf 5x100 fitting. If you get you own pads and discs just get them for a Octy vRS
Matt
Thank you for the replies and im guessing its bolt off bolt on no need to change brake lines/fluid etc. also will the Abs be fine.
Direct fit nothing else needed :)
you you`ll need to clamp the brake line, but it`s fairly straight forward. No abs issues or anything. There is a guide knocking about somewhere
Matt
Thanks for the help i will be looking into buying those once i have my coilovers
