Tow Straps
Where would you fit it anyway because you can see rear towing eye under bumper anyway and front ones only behind grill
you bolt them on to the towing eye so recovery has easy quick acess to your towing eye when on the race track
It tells you in the description they bolt to the chassis. You'd have to be careful on the vrs tho as the front bumpers pretty low and as said there's not much access with the front tow eye being behind the grill in the bumper.
On mine, I popped out the bumper grille, undid a 13mm bolt onto the front crossmember and bolted it up through there. It sits snug on the top but then hangs down nicely :o ; though if i was going to be towed on it, I'd pop out the grille, cos its going to be pulled out.
Awesome! Cheers guys B)
