Window problem!
Hi all, this just started today with no warning:
Drivers window is fine up and down.
Passenger window is fine up and down from passenger's controls.
Passenger window will only go down from Drivers controls?
I've seen a few places mention a key reset for windows, not actually seen how this is done - instructions appreciated.
I'm assuming because the window works fine from one side, and half works from the other side it's likely to be a loose or split connections? In which case I need to pop the driver's side door trim off and have a look - is this an easy job and any instructions anywhere?
Thanks,
Ben.
Key in drivers side door , turn clockwise until it locks then turn key anti clockwise and all should be fine if it's the reset is the problem , switch might be iffy
Seems to have worked - thanks!
No probs glad I helped, this comes up very often but there is so much info here(Briskoda ) you'll never be without a friend ;)
