Felicia 1997 tachometer
Hi Forum!
Anyone have a suggestion on what year a set of clocks would work with a 1997 felly that has a tachometer.. I currently have the analogue clock..
I tried a set of clocks that came from a y reg (2000) and the digital clock worked but the rev counter didn't move and the temp/fuel worked backwards.
Looking at the back of the clocks and comparing there are quite a few differences..
Thanks,
Lee.
You would need one from a mk 1 Felicia. I believe the rev counter gets its signal from the ECU which is completely different. I take it your car is a 1.3 SPi
I see,
Nope my car is 1.3 MPi :)
I see,
Sorted it :)
Got a set of clocks that came from a '97 felly 1.6 and they work fine :D
I bet you took the Airbag warning bulb out yeah? :giggle:
Not at all! All in working order :D
