O/S mirror indicator and footwell lights
At the top of today's list of questions to ask are a couple on light functions - or lack of.
I don't appear to have any footwell lights in my mkII VRS and don't know if I am supposed to. I have Maxidot which doesn't give me the option under lighting to change the brightness (like I can on the VW in our household). Should I have some and should they be working?
Secondly, the indicator in the driver's side mirror also doesn't work. I would have thought this would have thrown up a bulb out alert or made the indicators on that side both flash faster to show there was a lamp gone, but this also doesn't seem to be the case. Do I have a more serious problem?
Thanks!!
J
Footwell lights aren't available on the vRS but they are retrofittable.
If I remember correctly fellow member 'alberg' has done this and created a 'how to' thread on here somewhere.
As the repeater in the wing mirror is an LED it is not monitored by the CANBUS system so won't flag as a problem on Maxidot.
It's not simply a case of replacing the bulb either, you'll need a complete assembly, lens and all.
Not a lot of money though and easy to replace (access gained by removing the mirror glass).
Footwell lights are a halfdays job and looks high premium :rofl:
The wing mirror lighting not working, sorry can´t help you. Altough would be interresting if vagcom picks up anything. :wonder:
Thanks guys, it dud occur to me that the mirror light wouldn't flag as an error as it is LED. I ordered a new unit from TPS yesterday so will pick that up and replace it later today.
I'll look at the footwell lights how to as well.
Ta
J
Indicator sorted with the unit from TPS (paid less than the price I was quoted too which makes it cheaper than the local main agent). Slight panic when I thought I didn't have a T10 bit but soon found one before I spent more dosh.
Just have to find the footwell lights thread now!!
J
