Boost pipes
Hello, is there a kit out there, that replaces all of the oem boost pipes for uprated ones? A few of my boost pipe joints have alot of play in them. I have cable tied them up for the moment. Also looking for a 'dovit' pipe, if i go to a exhaust place, will they be able to make me one up?
Cheers, Theo.
Expensive can of worms. Due to the way all of the connections are machined to accept the OEM pipes, you need to do an EGR delete, new inter cooler, and nothing can be done at the turbo end connection. Problem now being, an EGR delete is going to be an MOT fail soon.
Even the OEM pipes are not cheap, but if you cable tie the new pipes to prevent movement, they last a lot longer.
I think i will just leave them alone for now then :)Thanks
Just found these on ebay
SFS
In theory its the same engine and look pretty similar to the oem boost pipes
anyone know if they will fit?
Edited by thealienfromura
