Help
Hi Please can I have help, on how do you remove the rear tailgate trim (hatchback)to install the rear sunblind. 2008 elegance It is not explained in the instructions that came with the part It talks about work instructions with a number(I guess main dealer info) I have found the torx bolt by the grap handle. It cant work out to how to remove the trim from then on? I did not want to pull to hard as the instructions mention you may need to replace broken clips. No clips in the sunblind box.
Whats the trick to getting the two sections off.
Thanks in advance
Thanks in advance
Hi
There is a guide here.
You can pull as hard as you like - the clips are spring metal and are robust. They are used in most of the plastic trim parts in the boot or along the cills and B posts.
They do fly off or get pulled out of position but they slide sideways back into their position with no trouble.
HTH
