can i keep the same bolts
If I change wheels from 38 offset to 43mm, does it mean i need shorter bolts? if so what size?
Offset has no bearing on wheel bolt length, are they genuine or aftermarket wheel?
I have oem wheels off a mark 4 golf (which are 38 offset, 5x100) and I want to replace them with oem fabia wheels (which are 43mm) and pcd 5x100), does this make a difference? My existing bolts can fit both wheels? what about the locking wheel bolt..i can keep that as well?
Edited by fabia55
Yup they'll be fine
that's great. thanks, I assume I can use the same locking bolts as well.
Yes you can.
