Left/right cabin air temperature discrepancy
I have a FL vRS and I have noticed that when the passenger and driver side temperatures are set to the same temperature the passenger side is always noticably cooler than the driver side. When I adjust the temperature the air at both sides changes, either warmer or cooler, but the passenger side always remains a bit cooler than the driver side. Is this normal or should they both be the same? Any (relevant :D )thoughts appreciated.
Sarge.
I have read the the wires controlling the individual climate controls can get worn causing the 'individual' part of the system to stop working but did not mention anything about one blowing cooler then other, worth a look i think though
Individual climate controls may not work properly. A chafed cable shows up on the OBD II diagnostics as a faulty control panel. Worth knowing because the control panel is £300. Confirmed by another reader. The cable chafes between the engine bulkhead and the dashboard causing an intermittent short.
* quoted from honestjohn.co.uk
