Coolant Leaks - What other part to replace
Hello Guys,
I have a 2002 Skoda Octavia 1.8T AGU Engine
At 52,000 kms I replace the Coolant Flange that attaches to the engine.
http://c1552172.r72.cf0.rackcdn.com/127445_x600.jpg
Now, at 55,000 Kms, I replace the 1JO 122 109AQ Hose Expansion Tank to Water Y Pipe
http://uspmotorsports.com/images/expansion_tank_hose_1J0-122-109AQ.jpg
I don't have more coolant leaks but to you guys, that have replaced these 2 parts, what is the other coolant part that is the next to fail that you recommend me to replace or keep and eye on.
THX
Edited by Turbo_Boss
If you have no noticeable leaks get a block dye test done to check the head gasket is ok. Water pump is a common failure too.
