Vrs Alternator
Basically the car had been messing about last night, throwing up ABS,Handbrake,Battery,Asr and power steering warning lights on and off...engine kept running but all lights window wipers etc cut out.. so pulled up and turned it off and called a recovery truck..... quick look under the bonnet earlier and fan belt was off the pulleys and the pulley on the side of the alternator was free to pull off,leaving a ceramic bit on the shaft coming out... anyone know a part number for the pulley?believe its referred to as a Auxiliary belt clutch bearing?
Or anyone have an exploded view of a vrs alternator?
any good motor factor should be able to get these.special tooling is required for removal and fitting tho
I have two knackered ones in the shed, I will try and have a look and get you the part number off the pulley tomorrow, the pulley is made by INA IIRC. The VAG part number should be 022 903 119C. You can even get them from a ford dealer as the engine and alternator in your car are the same as the Galaxy.
Lucky!! Could have taken cambelt with it!
How it's all in cased,
