Oily Drip
While under the Fabia doing an oil change last week I noticed what looks like thin clean(ish) oil waiting to drip off the bottom of a U shaped pipe.
Can't see anything above which might be dripping onto the pipe, so I guess the U pipe is weeping. Anyone know what it might be?
Thanks in advance.
David
Edited by dc63
Thanks for the pointer Chris, I've had a dig through the diagrams on www.vagcat.com and it does look like an aircon pipe.
Will get it into the garage for a quote, but probably expensive.
Cheers,
David.
If it is the aircon pipe...
...I may have a cheaper alternative to replacement if it's the pipe itself. If it's a join, then not ideal but if it's a pipe...
Then using fibreglass for repairs should be worth a shot.
I'm going to use some of:
http://www.pitchcare.com/shop/leak-repair/aquafix-wrap-repair-tape.html
In order to patch up my pipe.
I'll let you know how it goes :)
