Air-con
I have a 2007 Octavia and as soon as the ignition is on the air-con starts working as if it is switched on. The engine warms up in normal time but the heater will only blow warmish air inside and switching the control panel on or off makes no difference. I assume I have a sensor malfunction but I would appreciate any info you people can give me.
I did do a search but could not find this particular problem.
Many thanks
JD
Anyone?
Edited by jdcambelts
Many thanks
JD
Anyone?
Ok I have since found the problem. There is an ambient air temperature sensor that sits in the o\s\f chassis leg and one of the wires was badly corroded.
