4X4 rear bushes
I noticed that the rear passenger side tyre is wearing on the outside edge of my 2002 4X4 Octy estate, so I took it in to get the geometry checked. The guy tried adjusting the rear but failed to get it right as he ran out of adjustment? He said there was a bush gone. Has anyone go a diagram of the rear bushes, the Haynes manual doesn't cover the 4x4. Does anyone know what bushes I need and where to get them please? I've polybushed the front dogbone and ARB, so I'm happy to have a go at the rear, unless it's really hard? I presume the bushes are different to the 2WD model? Any help would be great.
Cheers 352
Probably means the bushes in the multilink rear arms, think they come with the arm.
Are the bushes the same as the 2wd version and are they hard to fit please?
Cheers 352
the bushes on the back look like a pita to change as all the bolts etc on mine look to be rusted well, the main one is the bush at the front of the Arm. I have the same symptom of tyre wear so need to get mine done soon as well.
That sounds just like mine, adjusted it as much as I could but still takes the edge off the tyre.Another job to add to the list!
