Would Scooby wheels fit my fabia?
Just wondered if anyone knows if the offsets are the same on imprezas and fabias. Any help would be appreciated.
No...
IRRC the hole in the middle is 1mm too small? someone will be along soon to confirm:)
No is indeed the right answer (to the best of my knowledge, as above sure someone will confirm shortly :thumbup: )
Yep, the centre hole is 1mm too small. If they are aftermarket wheels, try removing the plastic bit on the inside of the hole ;)
How handy are you with a milling machine? The centre hole is too small. But essentially no.
Edit: what Jon said :rolleyes: a couple of minutes ago
why would you want to stick subaru wheels on a skoda?
just buy immitations for
The question you should ask is not if they will "fit" but will they suit????
