pd130 head
does anyone know the part number for the VAG pd130 cylinder head, also are they all the same across the VAG range e.g. is the head used on ASZ engines the same as on BLT engines?
thanks for any info
I think so - 038 153 373 R - that's off a PD130 head, and seen the same on PD150 and even a PD105 (newer 1.9)
If you need one, send me a PM. ;)
EDIT: Don't trust my "5" in the part number above. Looking at the photo its not very clear. Could be 103 Edit: Confirmed it is 103 from another photo.
yh ive got 038 103 373 on mine and i might have to hold you to that depending on weather it passes the pressure testing and skimming when i drop it off to be done.
