Can anybody give me the ABS module coding from a Yeti 4x4?
Hi mates.
Well, as I write in the Topic Title, I´m trying to activate the Off Road function in my 2011 Scout. I think that Yeti and Scout share most of the parts and maybe the Off Road function could be activated in the Scout with some Vag-Com config and a button to turn it on/off.
A friend of mine gave me this ABS module ifo from a 2011 Tiguan:
Address 03: ABS Brakes Labels: None
Part No SW: 5N0 614 109 Q HW: 5N0 614 109 Q
Component: J104 C4 450 V2E7 0006
Revision: --H28--- Serial number: 00000003455329
Coding: 0002333
Shop #: WSC 01357 011 00200
VCID: 3957FBA809DF
If someone could give me the same info from a 2011 Yeti 4x4 would be one step more to compare with my Scout and study this mod...
Thanks in advance ;)
David.
Adress 03: Bromselektronik (J104) Labels: AER\1K0-907-379-60EC1F.clb
Artikelnr SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Komponent: ESP MK60EC1 H30 0107
Revision: 00H30001
Kodning: 913F400E092400FD890B02ED901C0049350000
Verkstad #: WSC 33361 790 00999
VCID: 7AF09EAA4C44
Ingen felkod funnen.
I missed the 2011, this is from my 2010 1.8 TSI 4x4
Edited by ola_h
This is from a slightly newer UK 4x4 Yeti than the one above:
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 933F400E092501FAC90E02E89020808A350000
Shop #: WSC 33361 790 00999
VCID: 76E8532F7857
No fault code found.
Wow!!! Thank´s a lot!! That´s an impresive quick answer!!
I understand that your Yetis have Off-Road button? Right?
I´ll try to check mine one today and I´ll post it on the forum. I´ll share this info with a couple of spanish friends (VAG-COM Gurus) and I´ll try to get some interesting info from your replies... :D
Can anyone with a 4x4 Yeti with no Off-Road button post it´s module info? And if someone with a 4x2 Yeti (ofcourse without Off-Road function) could post it too would be superb!! I hope with all this to get something clear.
Thanks, thanks, thanks!!!
Regards from Spain.
This is from a 2011 1.4 2 wheel drive:-
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
Component: MK70 M MASR 0105
Revision: 00H35001
Coding: 0017665
VCID: 7BF06BAA4375
Great!! :)
I suppose that only 4x4 versions could have Offroad button option...and not all the 4x4 have it. Is this right?
Post repeated...
Edited by Deivid
Great!! :)
Yes, that is correct.
Here you go Deivid a few more for you to compare, I have highlighted the differences in the codes for you - good luck! :giggle:
I am not sure which of the below have the "off road button" but I have included the info I do know.
(If any of the owners want their username removing from the log then let me know and I will remove it for you ... there is no info included that can be used by anyone with few morals shall we say :giggle: .)
900000 - Yeti 140 DSG 4x4 Elegance (MY11 - Nov 2010) c/w Off Road Button.
Revision: 00H31001
Coding: 933F400E09240101C90F02E7901C808A350000
VCID: 76E8532F7841
rockhopper - Yeti 140 DSG 4x4 Elegance (MY11 - Dec 2010) c/w Off Road Button.
Revision: 00H31001
VCID: 76E8532F7857
Thrompington - Yeti 140 DSG 2WD (IIRC) Elegance (MY11 - 60 reg)
Revision: 00H31001
Coding: 933F400E092501FFC90D02E8901B808A310000
VCID: 76E8532F7857
JCP - Yeti 140 (manual) 4x4 Elegance (MY11 - Dec 2010) c/w Off Road Button.
Revision: 00H31001
Coding: 933F400E092501FBC91002E5901D808A310000
VCID: 76E8532F7857
idrubie - Yeti 140 (manual) 4x4 Elegance (2009 59 reg - one of the 1st Yeti's)
Part No SW: 1K0 907 379 BA HW: 1K0 907 379 BA
Component: ESP MK60EC1 H45 0109
Revision: 00H45001
Coding: 933F400E89220003C90E02EC911C008A3100__ (2 digits less)
Shop #: WSC 35110 377 09999
VCID: 72E06F3F143F
HTH
Thank´s Gizmo... ;)
I apreciate very much the help from all of you...
I hope to get something interesting with this info.
Revision: 00H31001
VCID: 76E8532F7841
Revision: 00H31001
VCID: 76E8532F7857
No issues with you posting that Martin.
BUT how weird is that?!?! Rockhopper and myself have the exact same Yetis: 2,0 TDI 140 DSG Elegance and both have standard Off road buttons.... Why are there so many differences? And as you show above they are only a month apart in age!
And then to the OP: I've used my Off road button twice. It is amazing for sure but you really don't need it to go rough places. Llanigraham has an SE 4x4 Yeti sans said button and he will drive rings around anyone with this button engadged on an off-road course (I'm led to believe! :giggle: ) So I really won't go to all the trouble to install one. Unless you really, really need it.
I know Johann!
I can understand it if it was under 09-Central Electronics as the difference would be purely down to personal preferences (ie if one of you wanted selective unlocking and the other didn't etc) but the ABS I too would of thought would of been pretty identical between two cars the same spec and age :wonder:
I sure that the off-road button it´s something that we really don´t need in most of the times, but to me it´s a goal... :) I´m very curious with this things, and I like to discover this kind of secret tricks... maybe this could help Scout and Yeti owners without Off-Road Button. ;)
I know Johann!
That´s quite odd... would be very useful to have the description of the coding Bytes... On my VAG-COM I can´t do it. It shows a warning that says something like I can´t have this info and must request it to Rosstech... where could I found this info?
That´s what I get from my Scout:
Revision: 00H31001
Coding: 113B401C0A280002881202ED50220042310000
Shop #: WSC 73430 790 00092
VCID: 76E7E2EB7857
I check the adaptation channels and found this:
Adaptation Channel 097:
Stored value 0
Deactivated
N/A
N/A
N/A
Adaptation Channel 096:
Stored value 0
Deactivated
N/A
N/A
N/A
Adaptation Channel 049:
Stored value 0
Deactivated
N/A
N/A
N/A
Could you check if your Yetis have this channels activated or not?
Thanks, I feel that we are moving forward with this...
Thanks for that vote of confidence, Johann. :thumbup:
The OR button is there to make life easier for the unskilled or untrained, and to be honest can result in that driver going beyond his or the car's capabilities all to easily. Yes it is good for what it is, an AID, and nothing more than that. It cannot replace adequate training and experience.
So Graham,
Not sure if this has been asked before but how do you feel about organising a Welsh off road day so we can learn from the Master?
I, for one, would welcome such an opportunity, and I wouldn't mind paying for it either.
Talking of which, how many beer tokens would you require? :giggle:
I was hoping to arrange something along the lines of the Yeti Adventure I ran before, but slightly more "demanding", however work and family has got in the way. The problem is that I only get one long weekend off every four.
I doubt I would charge anything, to be honest, but never say no to a beer bought for me!
Watch this space.
My Yeti was registered December 2010 -PDI 5th January.
Equally no problem posting part of my scan-Gizmo, Martin,-one of the most helpful men I've met :thumbup:
Thanks ;)
Has it Off Road button?
Thanks ;)
Yes it has :thumbup:
Revision: 00H30001
VCID: 7AF09EAA4C44
Hi :)
a couple of questions... had this Yeti DSG and Off Road button?
There was no DSG on a 2010 1.8 TSI 4x4.
Yes there is Off Road button.
Thanks for the info... ;)
This Yeti was very nice...
  • 1 year later...
I'm sorry for my archaeology at first.
In ABS coding, bytes 05, 07, 09, 11, 13 are different in every car because these bytes are last 5 digits of VIN number.Probably Off Road Mode Button is coded in byte 14 bit 7 I think.
Edited by 1 6 D
