Measurements Required
Unusual request here! :wait:
I want to get produced the grey Yeti graphic as seen on the photo below and I also want to get produced an 'etched' look (maybe solid or maybe outlined) on the boot side windows using the same Yeti logo.
If possible what I would like is for some kind member :smirk: to measure the approximate height for the logo on the boot lid and also the dimensions of the side boot window so I can get them produced ready for our Yeti allegedly being built in December.
Dunno if the etched bit will look right but I'm gonna give it a go :(
As always my thanks to aerofurb and the photo of his car
Sorry I can't help with your query but do you have a place in mind to have them made for you, if not I have a suggestion of a great guy who'd be able to sort it out for you just outside Carlisle. A guy I've known for many years and is spot on.
I was thinking of a spot at Lillyhall, Workington - although I am always open to suggestions :thumbup:
A place called Sign-IT on Brampton road, Longtown. Good man is that, has spent many an hour helping me out with stickers.
Guess I'm going to have to find a Yeti somewhere
The area of the boot lid where the logo is -from the horizontal line to the bottom-before the slight flare is 23cm in height and from the edge of the number plate recess to the edge of the boot lid is 25cm in width.
The fixed rear window is 44cm wide and 42cm in depth.
These measurements are taken with a domestic tape measure in the near dark and are only reasonably close.
The Logo size you will have to estimate from the photos knowing the size of the area.
I'm ashamed it has taken so long for me to get round to this-Like everyone else I expected someone to do it any minute.
Hope this helps!
Hope this helps!
Many thanks for taking the time to do this for me - I can now start the process of producing a template. :thumbup:
I'm really quite excited to see how the 'etching' turns out (quite sad I suppose but what else can I do while waiting for the Yeti to turn up!) :smirk:
Hope this helps!
JCP,
Can I trouble you to confirm the vertical distance either side of the number plate (looks like a recess)?
Not had time to measure the distance (hectic day clay pigeon shooting :giggle:) but here is a old picture of the tail gate if you increase the size it will give you an idea of the shape
I posted it as 23cm -that is the flat part-there is a slight flare at the bottom which I didn't include. You can see what I meant in the picture :thumbup:
Many thanks for that - I can now do something constructive while waiting for build confirmation! :wonder:
