Octavia mk 2
Hi everyone i was hoping someone can give me some advice i have a 2004 octavia mk2 1.9tdi, it felt light the clutch started slipping although the revs never increased when i put my foot down but it is very sluggish picking up speed, then the management warning light came on & stayed on with a warning message saying "workshop imissions" that comes on every so often, i wondered if it is something i can sort out myself or do i need a garage, i have put a code reader on it & the codes i am getting are as follows
18104
18058
17056
17057
17058
16683
10655
unfortunately none of these codes are in the code reader book i would be really grateful if anyone could advise me Thanks
18104
18058
17056
17057
17058
16683
10655
If the codes are relating to VAG-COM / VCDS then there are quite a few problems there.
This is what i could find
18104 Powertrain Data Bus: Missing Message from Instrument Cluster
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Fuse(s) faulty
Databus Wiring and/or Connector(s) from/to Instrument Cluster (J285) faulty
Possible Solutions
Check Fuse(s)
Check Databus Wiring and/or Connector(s) from/to Instrument Cluster (J285)
Check/Replace Instrument Cluster (J285)
 Check Measuring Value Blocks (MVB)
17056 Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
Possible Symptoms
No Pre-Glow Period
Poor Cold Starting
Possible Causes
Glow Plug Wiring faulty
Glow Plug faulty
Possible Solutions
Check Glow Plug Wiring
Check Glow Plug
17057 Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
Possible Symptoms
No Pre-Glow Period
Poor Cold Starting
Possible Causes
Glow Plug faulty
Possible Solutions
Check Glow Plug
17058 Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
Possible Symptoms
No Pre-Glow Period
Poor Cold Starting
Possible Causes
Glow Plug faulty
Possible Solutions
Check Glow Plug
16683 Boost Pressure Regulation: Control Range Not Reached
Possible Symptoms
Reduced Power Output
Limp Mode
Possible Causes
Hoses/Pipes incorrect connected, disconnected or leaking
Charger Pressure Control defective
Turbocharger faulty
Diverter Valve faulty
Possible Solutions
Check Hoses/Pipes to/between Components
Check / Clean / Replace Charge Pressure Control
Check Turbocharger
Check Diverter Valve
Special Notes
When found in 2.0l TFSI:
Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06H-145-710-D (or newer).
RoW vehicles see: TPI 2016331 for details.
NAR vehicles see: TSB 01-07-70 or 2013392 for details.
If the Turbocharger is faulty due to mechanical / internal problems or the exhaust system is restricted (typically the Catalyst) this fault may be the end result.
Edited by Deneo
Possible Symptoms
Possible Causes
Fuse(s) faulty
Possible Solutions
Check Fuse(s)
Possible Symptoms
No Pre-Glow Period
Poor Cold Starting
Possible Causes
Glow Plug faulty
Possible Solutions
Check Glow Plug
Possible Symptoms
No Pre-Glow Period
Poor Cold Starting
Possible Causes
Glow Plug faulty
Possible Solutions
Check Glow Plug
Possible Symptoms
No Pre-Glow Period
Poor Cold Starting
Possible Causes
Glow Plug faulty
Possible Solutions
Check Glow Plug
Possible Symptoms
Limp Mode
Possible Causes
Turbocharger faulty
Possible Solutions
Check Turbocharger
Special Notes
Edited by g4ran
Hi Deneo someone said it could be the ERG so i stripped mine down & it was caked to hell so i cleaned it all up but it didn't seem to make any difference however i did notice that when i put my foot down the rubber pipe that comes off the ERG opposite side of the manifold sucks in, i just wondered if you had any ideas what could be causing it any advice would be gratefully received thanks
Possible Symptoms
Possible Causes
Fuse(s) faulty
Possible Solutions
Check Fuse(s)
Possible Symptoms
No Pre-Glow Period
Poor Cold Starting
Possible Causes
Glow Plug faulty
Possible Solutions
Check Glow Plug
Possible Symptoms
No Pre-Glow Period
Poor Cold Starting
Possible Causes
Glow Plug faulty
Possible Solutions
Check Glow Plug
Possible Symptoms
No Pre-Glow Period
Poor Cold Starting
Possible Causes
Glow Plug faulty
Possible Solutions
Check Glow Plug
Possible Symptoms
Limp Mode
Possible Causes
Turbocharger faulty
Possible Solutions
Check Turbocharger
Special Notes
Hi guys i'm back again, i've had the car at skoda on a diag machine & i'm told that the glow plugs need renewing & also the glow plug control unit J179 needs replacing, i've found the glow plugs but can anyone tell me where i can find the glow plug control unit J179, the loom from the glow plugs run into a cable tidy tubing down towards the nearside underneath the front of the car, i would be greatful for any help thanks.
