DPF and Fuel Cleaners/Additives
Will using a fuel cleaner/additive like Millers Diesel Power Plus cause havoc with the DPF???
I'm picking up my new vRS (PD) tomorrow and am keking myself after reading all this nightmare stuff about DPF.
I want to run some sort of cleaner through the first full tank to derv next week as i'm doing a 300 mile journey.
Is this safe to do?
Is this safe to do?
It should be fine. Millers specifically changed the formulation of their diesel additive about 4 or 5 years ago so it would be compatible with DPFs.
duplicated post
Happy days. The cars only done 36k and it's early 08 so i'm guessing it's only been driven around town. Will be good to give it a good clean out from Belfast over to the Lake District :rock:
I used Millers Power Sport 4 (Diesel) in my previous car and it did it the world of good.
I'm going to try some Millers EcoMax in this one shortly.
Why do people worry about dpf ,had my 08 car from new never had any problem with dpf,apart from light came on once so. gave her a bit of a blast and fine again,
In any case I seem to recall the problem with earlier Millers diesel additive was not with the DPF itself, but with the additives some systems like the PSA/Ford DPF setup add automatically to the fuel tank each time you fill up. It was this stuff that the old formula Millers reacted badly with in the tank, and I think was causing clogging of the fuel system in some cases. No such problems with the Octavia as its DPFs have never used any type of automatic additive dosing system.
I've tried this stuff and I think the car doesn't regen as much. Once a Year Treatment
JML DPF Cleaner
Can the 'regen' process be started via VAG.com?
JML DPF Cleaner
Yes I have found the same- dpf light only on once in 3 weeks of town driving- usually comes on once a week
Car has been remapped which makes regen much more frequent
Yes, Regen can be done via VAGCOM ./ VCDS
[select]
[01 - Engine]
[Coding-II - 11]
Enable Regeneration by Entering 21295.
[Do It!]
[Meas. Blocks - 08]
Select both Groups at once 070 and 075.
[Go!]
MVB 070.1: Regeneration Status (xxxxxxx1 = Normal Regeneration active, xxxxxx1x = Forced Regeneration active)
MVB 070.3: Regeneration Counter/Timer
MVB 075.1: Exhaust Gas Temperature before Turbo Charger
MVB 075.2: Exhaust Gas Temperature before Particle Filter
MVB 075.3: Particle Filter Load
MVB 075.4: Exhaust Gas Temperature after Particle Filter
Now Start the Driving Cycle and keep watching the Measuring Blocks
(Driving Cycle):
Vehicle Speed between 30-60 km/h (18-37 MPH)
Engine Speed between 1500-2500 RPM (4th or 5th Gear, Automatic Transmission in Tiptronic)
Duration approx. 15-20 Minutes
Exhaust Gas Temperature before Turbo Charger above 700 °C
[Done, Go Back]
[Close Controller, Go Back - 06]
Edited by Deneo
I'm sure manufacturers of modern engines sleep better in their beds at night knowing that there are people out there who simply HAVE to mess with what they burn.
Two words "Snake Oil"
