U280 Code scanner
No the scanner plugs directly into the car, the linked cable is to run a copied version of VCDS on a laptop.
These scanners are limited to what they will do do, but if all you want is a code reader and to erase (most) codes then it's a cheap way of doing it, don't expect to be able to change any settings with it though.
as above. I have one of the U280 scanners and it's brilliant :thumbup:
Thanks guys, I thought as much - yes all I want to do is read them and erase them (obviously after trying to fix/work out if something IS broken, not simply erasing to ignore!)
Zoe
Edited by Zoe
