heater directional switch
Had an issue today trying to figure out where the flexible connection between the heater directional switch (changes between windscreen front vents etc) and the housing for the flaps. With the heater control module removed looking in the space up in the top right hand side facing down is a small hole. Its near impossible to see i haf to remove the carpet on the side of the dash to see into it. Its just a case of turn the connection and push up till it falls into place then place the heater module back in while holding the flexible connection in place. Screw back in job done.
Hope this helps someone i spent an hour looking for the hole to put the connection in and couldnt find anythin on here to say where it would be.
