Hi I am new to this forum
I have an 07 Fabia Vrs and there is a problem with the anti skid warning light on the dash which comes on when it feels like it for no apparent reason, and now it has been joined by the coolant warning light when starting from cold; is this a common problem?
Hello, welcome to Briskoda.
Coolant light will require a new header tank, the prongs of the internal sensor have become crusty blocking the signal so it thinks the level has dropped. Less than £15 from a dealer.
ASR or ESP light could be a few things but I bet the load signal wire has either corroded or broken on the two pin plug in front of the gearbox, easiest repair is to bypass the connecter and join the two wires direct. A fault code check would confirm this though.
Hi and welcome aboard.
