Agenda for today LOTS
Well the day has finally come and all the parts have arrived and been made so thanks to rob for all the write ups
Getting fitted and removed is the
N249
Secondary air pump
N112
Grounding kit
Sailko Michi occ
Neuspeed induction kit so don't have to blank off the original box
Here it goes and will take pics along the way especially of the cuts and blood loss
Have fun m8 and get the plasters ready! lol
Good luck! And have fun :-)
Hope you've got enough jubilee clips :thumbup:
Be careful round the breather pipes they get very brittle with age
Just replaced all the breathers as they were old and split, used robs write up an added a catch can. Little problem
With that though as it seems I ordered a can with 11mm fittings instead of 19mm so gonna have to get a reducer.
Everything is now removed and fitted, not bad as it only took 1.5 hours and the write ups were invaluable
Pics coming soon oh and no blood so it don't really feel like I have done anything, I'm sure your supposed to bleed when working in a car
Edited by Skud Kid
After a freezing cold day i finally gotten finished but i still need to remove the n249 and the 112 valve and remove the vacuum reservoir but the grounding kit, sia and the induction kit are on. Early start tomorrow should see me finished with theta stuff and the removal of the rocker cover to get blasted and coated
By the way if anyone wants me to do a grounding kit for them i can TO THE MODS I'm not selling anything here i will literally do it for the cost of the parts, we have all the heat shrink and battery terminals at work so its just a case of the cable, i used 4 wag which to be honest i think looks really good too
Anyway a few pics of what i did
dont think the catch can will work very well lol
Sailko Michi occ ????? did you get sent the worng one as the stage 3 should have 19mm outlets ??
+1,
I was thinking that. Hot dog down a well situation?
Also whats with the DV? Is that the new forge one, or is that a blow off valve?
Looks like a forge split R, adjustable recirclating and blow off
What is the idea / thinking behind the grounding kits
