fault codes 16490, 16891 & 16804, help with diagnosing?
engine management light came on a couple of days back, i've been waiting for a cheap code reader which gives me the following -
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
16891 - Idle Control System RPM: Higher than Expected
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
any ideas?
could this be down to a leaking vacuum pipe?
it's the third code has me worried, could that be related or is it likely i have a bigger problem with the cat also?
Edited by jkp
cheers mike.
