Exhaust Gas Pressure Sensor part number request
Following on from my other recent threads, my car had 2 faults showing.
First one I have sorted by replacing the Camshaft Position Sensor, just got the second one to sort now.
I need to replace the Exhaust Gas Pressure sensor.
The car is a 2.0 PD140 DSG DPF, the engine code is BMP
Now looking for the part number for the above engine for this sensor.
The car is now out of warranty, hence the DIY approach.
The sensor will have to be calibrated when it is replaced before the car can be driven just so you know.
The sensor is otherwise known as G450.
The part number is 3U0131552B
Tony
As the fault was showing as intermittent is it worth just clearing the code and see if it comes back. I need to get the other fault code cleared anyway so this will go with it when they are erased.
Managed to get faults cleared today. Engine light is now off however the G450 error "Signal to high" comes on as soon as its cleared but at least the engine light stays off.
The part number Tony posted seems to be the wrong one, in that its for a whole assembly.
Did some more digging and came up with part number: 076906051A
I now have one of these on order, hopefully should have it before Christmas.
