Remove interior door handles?
How do you remove the interior door handle to get to the window switch? I heard the brackets snap very easily!
What are you trying to get to?
From memory I removed the window switches by pushing the blank arm rest bit behind the switches up, then sliding it off. Then there's a hole underneath the arm-rest assembly thing against the door-card, that leads to a tab which needs to be released. It took me a while to get it when using a long screwdriver, but it should be possible.
I think that's accurate, but it's been a while since I've owned a Fabia.
My windows arent working, got a new drivers side switch to fit. ill give your way a shot. Cheers
