Intake flap / throttle body (V157)
Hi all, I've recently had the dreaded fault code come up to do with the v157 intake flap failing, having read through the forum I'm off out to buy the 10a fuse 8 to see if that solves my problem, if not I'm going to have to get the replacement part.
For info, 2006 Fabia VRS, BLT engine code.
Been to the stealers and they quoted something around 360 for just the part & a specialist independent 400 fitted, having done a little bit of googling I've found it for £246 on eurocarparts (however this doesn't quote original part number and doesn't show blt engine code so I'm sceptical about it being the right part.
http://www.eurocarparts.com/ecp/c/Skoda_Fabia_1.9_2006/p/car-parts/engine-parts/fuel-and-engine-management/throttle-body-service-kit/?422440260&1&9c64d2e605037eb8a3f8ff40ba523772a07f1ee8&000329
I've also found the below which seems to be more promising (and a fair bit cheaper too),
http://www.darksidedevelopments.co.uk/products/vw-audi-1-9-2-0-anti-shudder-valve-asv-038-128-063-m.html
My main question is is there any difference between part numbers 038128063L and 038128063M? I assume it's just an evolution, and will be fine as a replacement.
James
Hi,
A quick ckeck on EKTA the parts listing program shows that 038128063L is suitable for the Fabia, the one finishing in M isnt,
Tony
