Rear Window heater not working..
Got into my car this wekend and it was soaking with condensation. Literally dripping... :'(
I put the rear window demister on. Made sure the mirror swatch was centre...and after 2 hours it had not cleared the rear window.
Usually its done in 15 mins tops...
Coudl this possibly be a fuse? Anyone know which fuse it is? I'll probably need to go find that fuse diagram again if it is!
F39 20amp
F39 20amp
Cheers :thumbup:
Only half mine demists , is the actual wire in the window broken or?
The bar thingies on the glass can be damaged. You can use conductive paint to repair it, if you can find the break. One of the lines on mine doesn't work though can't see where the break is.
There is normally a hot spot on the line where the break is. Breathe on the line until you see a bit that clears your breath-good weather for it.
