Fuel filler cap broken
Hi all,
I'm suffering a problem I'm sure I have heard about on here but now can't find a solution. The fuel filler flap has broken on my fabia vrs 1, had always been fine up to now, does anyone have any ideas on how to fix this?
If you pull down carpet in boot you should be able to access the rear of the filler. Think the end piece of the cable has come lOose so have a look also there should be an emergency release so you should be able to fill up
This was brilliant, turned what i worried was a £200 job into a 20 second job!! brilliant, thankyou both!
So much easier than I feared it might be! Thanks for the tip :)
