Headlight washers
Why are they blowing the fuse when i use them ?
cheers James
Made sure the fuse is the correct amp?
Does the fuse blow immediately? If so, suspect a short circuit somewhere.
And the short circuit could be within the motor itself.
  • 2 months later...
To save starting another thread,
I have washers and since the cold snap and them freezing up I cant get them to work?
I thought they just poped the pipe but when I took the bumper off the pipes were all fine.
My fuse went when everything froze up and I changed it with the 10amp fuse is said should be in there where someone had put a 15 or a 5 cant remember now.]]do you need to vcds them to tell something they are there?
cheers
billy
