Fitting cruise control
Hi there got a cruise control stalk for my 06 octy vrs and was wondering if anyone had full instructions as got a manual for fitting with the kit from skoda but the translation to english is pretty poor and seems to say that i need to fit the kit and not the extra wiring in the kit but also mseems to say that i need to fit the wiring. any help with this would be appreciated as wanting to fit asap. also would anyone have the activation code for this as have a diagnostic tool that code but cant seem to find what i need to put in to activate. ps thanks to all the poeple that helped with the engine management light issue i had as have sorted it now and car is perfect. thanks to anyone that can help
Unless you have something like VCDS or VAGCOM entering the login code of 11463 wont be possible.
On an 06 Octavia you shouldn't need the wire, that was only for early 04-05 cars.
That's great thanks very much will get it fitted and know a guy with vag com so should be able to code will keep you posted on how I get on cheers again
