1.4 MPi with sludge in coolant
UPDATE...
After a few months, a little sludge appeared in the coolant which I put down to being residue not cleaned out of the system fully as it didm;t get any worse until last week.
We had been having issues with the coolant light coming on which prompted me to investigate. I kept an eye on the coolant sludge over about 2 months and it was only in the last week that it suddenly got worse.
The expansion tank has a little sludge in in (on the cap) and a drop in the coolant, but it has turned a darker brown (with a hint of pink) and stained the expansion tank.
No sign of coolant in the oil though. Nothing on the oil filler cap or on the dipstick.
I've a new coolant tank on order along with G13 coolant. I'm going to do a oil & filter change along with the coolant reservoir and coolant flush / change.
Aside form the obvious, does anyone have any thoughts on this development or the process I should be doing (e.g. should I use something like Wynn's engine oil leak stop?)
  • Replies 50
  • Views 16.8k
  • Head gaskets are very common place but an easy DIY job. See if it's got a modified gasket on it anyhow, identified by temac or a T written on the right hand front corner as you look at the engine on
  • Update. Eight months on and two days work and it's done (almost). It did look as though the head gasket was leaking and some of the manifold gaskets had been blowing a little. It seems like a broke
  • I found Normfest CC442 radiator flush far superior. Euro Car Parts used to stock it. Seems it's available here http://www.type911sh...d=894&aid=4232 and to be honest the price is about the same as
