Anyone used gutter sealent leaky doors, does it work?
Hi Everyone,
I have read quite a bit on the forums about the leaking door carriers on early fabias,
Mine was leaking quite badly so repaired with black no-nonsense gutter sealent, will this work?
Seems to be a lot of people using different sealent but I am hoping this sealent will work?
Thanks a lot for your input!
Hi Everyone,
My rear door was leaking on closer inspection found out it had already been sealed before with what looks like gutter sealent so searched the net & found this.. seems to be working now need to do the fronts.........
http://www.ebay.co.uk/itm/220895620463
Ever Build Stixall Extreme Power Universal Instant Grab Adhesive Wet Sealant
If you read or have read the leaking rear door thread most as you use the black gutter sealent.. i just wanted to try something different.. :)
I used gutter sealant and it has worked fine for me
Phew!! that is a relief! i used a full tube for both rear doors, the front ones seem fine lol :)
Me and mate used b&q black gutter sealant and its worked a treat!Been on cppl months now
I used unibond roof and gutter sealant and it was fine after two years.
I used Wickes roof and gutter sealant on mine and Bezzy's car and it seems to have done the trick. Been on for several months now.
Thanks guys! that puts my mind at rest!
Just to confirm, is this the one you used?
http://www.wickes.co...nt/invt/240691/
My Car needs to be done, a horrible smell and very wet after yesterdays bad rain.
Yeah that's the one
Gutter sealants probs the best for the job!
Far far superior to silicon
Yeah that's the one
Cheers mate, much appreciated.
Cheers for that mate, many thanks.
no worries mate i hope you get it sorted, its easy enough and only took me 1.5hrs for both doors and so far so good
